SDK won't debug or run ("cannot parse XML target description")
I had problems both debugging and running something I was able before, can't figure out why.
I created a fresh trivial hw + sw project for Zynq Ultrascale+, just the Zynq MPSoC with the minimuum peripherals and its wrapper. Exported hardware and created an FSBL app for the a53 core. Launched the debugger with the settings below and got the error at the end.
What is that "XML target description"?
It seems GDB doesn't work... System Debugger does.
So I will use the latter, just wonder if GDB cannot be used or I'm missing something
