nishith.kumar
SDK working problem after upgrading 2015.2 to 2017.4
Hello everyone,
                      Previously we were working on sdk 2015.2 our project was working fine, The same working project we are trying to build on 2017.4 without changing anything. First we used to get disassembly window after we adding extra compiler flags in BSP setting, The disassembly problem is solved but it's entering into exit mode immediately after we resume project. Here attached sdk screen shot after redirecting to sdk.
 Any suggestion would be appreciated.
Thanks and Regards
Nishith Kumar
pvempati
Hi @nishith.kumar
What is the extra compiler flag you added in BSP? Actually in 2017.4 "-g" flag is missing in BSP flags.
Please add "-g" in BSP settings and then re-build the bsp and application.
Thanks & Regards,
Praveen Kumar. V
nishith.kumar
Hi @pvempati thanks for your valuable reply
                         -g is only the extra compiler flag we added, but we facing the same issue.
In sdk 2017.4  sdk log window we can see error messege:"Failed to Connect to HW Server, Reason: Command [C 1847 RunControl getChildren "JTAG-jsn-JTAG-HS3-210299A1F9C8-4ba00477-...] aborted".
in previous version 2015.2 we were not getting such error messege. we were recieving restored data correctly.
 (we are using cypress fx3 usb to recieve data from fpga ) . while using 2015.2 we used to receive proper output from FX3 USB.
After upgrading to 2017.4 we're facing the above problem, and we're recieving constant unexpected (white image, hex values FF ) data from fx3.
The attathed files are screenshot of SDK 2017.4 error messege  and  FX3 receiving side data.
PS: We have not changed single line of source code from previous version, we just added extra compiler flag that's it.
thanks regards:
nishith kumar.
