mshin
SDK_xilinx gdb launch is not supported from 8 series
Hi.
I worked with mucroblaze in kintex 7 without any problem, now I migrate to kintex ultrascale ku040 and in sdk the error below has been appeared:
"xilinx gdb launch is not supported from 8 series"
And I can not use GDB to run or debug.
It also immpossible to run the code in other type of configuration.
Any one could help?
sadanan
GDB based debug is supported for all targets/devices from SDK 2018.1 release. You can also use system debugger
sadanan
