SPI flash test example
I am using Xilinx evalution KIT of ARTIX-7.
I've created new application project based on "peripheral test".
It contains spi test for the flash (using device ID XPAR_AXI_QUAD_SPI_0_DEVICE_ID).
But I see that the test only reads spi registers, but does not do any read/write to/from flash.
I would like to do testing of read/write from flash with the evalution kit.
Can anyone please direct me how I can start doing it ? Is there an example ?
Thank you!
Ran
Re: SPI flash test example
Check the example xspi_numonyx_flash_quad_example.c  file in C:\Xilinx\SDK\2014.4\data\embeddedsw\XilinxProcessorIPLib\drivers\spi_v4_1\examples directory.
There are few functions like SpiFlashRead(), SpiFlashWriteEnable() and SpiFlashWrite() for your use.
Additionally, refer to http://svenand.blogdrive.com/archive/201.html#.VVxKefmqpBc to know about how to program Spi Flash.
Praveen
This is the hdf I'm using with the evaluation board:
https://drive.google.com/file/d/0B22GsWueReZTNWlVVG1pTVd6eDA/view?usp=sharing
Praveen
The build fails now on undefined XPAR_INTC_0_SPI_0_VEC_ID.
I guess that the HW missed adding the spi flash interrupt into interrupt vector controller.
I'll add it, and then try again.
Thank you very much,
Ran
