Observer appu1
Sdk error
Hi to all
After generating bit stream  I launch SdK, initially it open normally , next time  when I open it showing error as shown "sdkpng"
after reading information provide in given link , i change network connection to direct and in sdk log trace.
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-launch-error/td-p/800805
after apply those , I am attaching  png of those in sdktrace ans sd png
Re: Sdk error
Hi @appu1,
So it seems some kind of workspace issue was affecting to your enviroment. Please mark your last answer as solution so we can monitor the issue is been solved for you.
Ibai
Ibai
Re: Sdk error
Are you launching the tools from a network server?
Re: Sdk error
Hi @appu1,
Are you still facing this issue? You did not came back with any further comment so just wondering if you solved your issue already or not. If so would be great to share you solution as that might help more people on the community.
Ibai
Ibai
Observer appu1
Re: Sdk error
I did not get my solution, but In other project its working fine . so I make another one
Re: Sdk error
Hi @appu1,
Ibai
Ibai
Observer appu1
vivado enternal exception
@ibaie
In same project when hit for synthesis some wierd java  error is coming. I am attaching the screen shot.
1st png when hit the synthesis and another one when choose to continue.
I was not sure where to post this query so I posted in this cos same project with different issue
