Set MIO GPIO pin on ZynqMP from FSBL
I need to set a GPIO pin from FSBL.
I am currently patching the psu_init* files after creation (The mask write), though would expect that I could control this from Vivado. I cannot to find a place to control the direction.
Opening the Zynq UltraScale+ MPSoC IP core, gives access to Peripheral -> Low Speed -> I/O Peripherals -> GPIO and then the GPIO pins. The direction is fixed on inout and I cannot set the default direction / level.
Is there not a way for controlling GPIO to FSBL?
Thanks for all your input.
Though need the GPIO to be part of the psu_init as they enable clocks used for pll locking later in the sequence.
So still hope for the HDF to contain the initial GPIO level in future version of Vivado.
Claus
In FSBL we generally enable GPIO, but not define the direction and the value (if it is output).
They are done in the application. Following are the bare metal APIs to set the direction and the value to GPIO.
XGpioPs_SetDirectionPin(&Gpio, Output_Pin, 1);
XGpioPs_SetOutputEnablePin(&Gpio, Output_Pin, 1);
XGpioPs_WritePin(&Gpio, Output_Pin , 0x1);
Ravi
Thanks for your reply.
Unfortunately I need this to be done in the FSBL, so will continue to patch the FSBL.
Why not give option for defining direction and value in Vivado project?
I think you are doing this for the AXI-GPIO IP core.
Claus
You can try doing the same on FSBL. Add this functionality in the standard FSBL project provided by SDK.
The APIs that I mentioned are for PS GPIO.
Have a look at PS GPIO driver.
Regads,
Ravi
Add the code to fsbl hooks fallback. You can use the xil_Out()
See wiki page here where I did something similar
http://www.wiki.xilinx.com/Execute+Microblaze+Application+from+PS+DDR
Claus
