bhig
Setting breakpoints on lines relative to a function
I couldn't find any information about whether or not breakpoints in SDK can be set through the xsct "bpadd" command to be a line number relative to a function rather than just a file.  I was hoping maybe there was some way through use of the "-properties <dict>" or "-meta-data <dict>" options but so far have been unsuccessful in finding any documentation on what those options can be used for.  I'm currently using SDK 2017.2.
Any info would be great, thanks!
sadanan
Line breakpoints relative to a function are not supported in GUI or XSCT
sadanan
