Shared memory across processors only works while debugging.
Hello this is my first post so I am sorry if this is not the correct location to post. I am running a different program on each core.
I just started this project and I have created test code to verify I am on the right track using shared memory.
void testLock(PROC proc)
	XSharedResources resources;
	// processor 0 will lock and unlock the shared resources
	if (proc == 0)
		for (int i = 0; i < TEST_LOOPS; i++)
			std::cout << "PROC[" << proc << "] has UNLOCKED resources"
					<< std::endl;
			resources.unlock();
			sleep(5);
			std::cout << "PROC[" << proc << "] has LOCKED resources"
					<< std::endl;
			resources.lock();
			sleep(5);
	// processor 1 will print out the state of the lock
	else
		std::cout << std::boolalpha;
		for (int i = 0; i < TEST_LOOPS*2; i++)
			bool state = resources.isLocked();
			std::cout << "PROC[" << proc << "] LOCKED = "<< bool(resources.isLocked()) << std::endl;
			sleep(2);
void XSharedResources::lock() { Xil_Out8(BASEADDR + LOCK_OFFSET, true); } void XSharedResources::unlock() { Xil_Out8(BASEADDR + LOCK_OFFSET, false); } bool XSharedResources::isLocked() { return (bool) Xil_In8(BASEADDR + LOCK_OFFSET); }
I see the desired output only when I 'Debug As'.
PROC[0] has LOCKED resources
PROC[1] LOCKED = true
PROC[0] has UNLOCKED resources
PROC[1] LOCKED = false
When I do a 'Run As' it doesn't seem to work correctly and I get this output.
Been banging my head on this one for awhile and would appreciate any ideas.
Hi ashton.allen.ctr@ncte.hpc.mil ,
It seems that you might be facing a cache "issue". The write operations are done in the cache but unless you flush the cache manually there is no guarantee that it has been written in the DDR memory, that´s why the second processor does not read the latest value.
Ibai
ibaie,
That fixed the issue I was having thank you so much!! Would it be acceptable to just disable cache? what would the rammifications be?
The apprach you want to follow depens on your needs or basically your application needs. You could find lot of information about caches in the processors (not specific to Xilinx) but in a nutshell the cache allows you to have better performance on the memory access (as you don't need to go up to the DDR to read/write your data). The issues is that with an heterogeneous system (i.e. two processors) the data gets "unsynchronized" on the cores.
Ibai
