Simulating MicroBlaze MCS
Hi Guys,
I am having trouble simulating MicroBlaze MCS.
I am using WebPack ISE 14.7
I have followed the steps outlined here: http://forums.xilinx.com/xlnx/attachments/xlnx/EDK/30029/1/mcs_sim.pdf
When I add the bram.mem files to the project I cannot set the association to Simulation, only to None or Implementation.
Weh I run the simulation a can see the Trace_PS signal changing and the Trace_Date_Byte_Enable changes to 1111 but no other signals change.
My guess is that ISim is not loading the bram files, has anyone any pointers to what I should check.
Many thanks
Andy
Moving to correct board.
Debraj
