davet
SmartLynq Required TCP/UDP Ports
I have an Ethernet-attached SmartLynq that I'm having trouble using. I'm pretty sure that I'm running into some firewall issues, and would like a complete list of known-ports that are required to use the SmartLynq.
I know the hw server on the SmartLynq accepts TCP connections on 3121. I can connect to this using Vivado hw manager and program the FPGA just fine.
I'm seeing some blocked UDP traffic on my local machine from UDP 1534. This seems to be related to the symbol server that Vitis starts when debugging the processor, and I've requested that my IT folks open up this port on my local machine.
Are there any other frequently used ports that I should get opened up?
