Advisor
Advisor
SmartLynq with SDK : does not stop at main, failed to plant a breakpoint, does not show source code when halted
I"m using my brand new SmartLynq JTAG probe, and trying to debug bare metal code in SDK (2018.2)
I created a simple 'hello world application' for my Zynq device, that I modified slightly so it outputs 'hello world' on PS UART1 each second, in an endless loop.
I can program the bitstream, so my SmartLynq probe works fine and is connected to the target.
However when I want to (source level) debug my code through system debugger, the following 3 issues occur :
1) my application immediately starts running, instead of halting in 'main', although I set this checkbox 'Stop at main' in my debug configuration. Note that my application properly works, it says hello-world eery second on the serial port.
despit this, my application just starts running:
2) I cannot put a breakpoint anywhere in my code, if I double click to set a breakpoint, I get the message: failed to plant: Unresolved source line information
3) if I hit the 'pause button in the debugger, I just get a 'Disassembly' window, without any source code info in it, and a call-stack without any function name next to it :
so SDK seems to have no symbol information ... however right-clicking on the A9 MPCore #0 -> Symbol files shows  that the .elf file is known by SDK:
4) If I switch back to my Digilent HS2 or HS3 USB jtag debugger, everything works just fine ...
Advisor
Advisor
After 2 days of searching in all kinds of wrong directions, for example here   (long story, but during the process I was also create a new VM, used the SmartLynq for the first time, I was also testing my git version control system and build script and thought the issue came from there, my original project debugged just fine, but my recreated project did not  ... see this related post)
 I finally fixed this issue...
The SmartLynq manual nowhere mentions that you should turn on that small checkbox when connecting to the target: 'use symbol server'
Once you think of it, it sounds of course very logical : the SmartLynq is considered a remote debugger, vs. for example a USB JTAG debugger, which it considers to be a local debugger ... but I simply looked over this a few times, I just 'replaced' my USB JTAG probe with an ethernet connected JTAG probe on my local desk, so who cares about symbol servers when remote debugging :-)
It would have been great if this was mentioned in the user manual ..., so I'm posting it here in case anyone runs into the same issue :
Advisor
Advisor
Advisor
Advisor
so please Xilinx, add this to the manual ... or even better, turn this on automatically if you enter an IP address / remote debugger ...
Advisor
Advisor
Xilinx has created AR# 64759 SDK - How to debug a remote target to answer my initial question
Another interesting one to look at if you have SmartLynq issues is AR# 69590 - SmartLynq Data Cable Master Answer Record
