Source address of CDMA
Hi all,
I'm testing CDMA to copy some data from main memory(DDR3) to BRAM on PL
But there is a problem with source address of CDMA
        u32 u32TestData = 0xFFF8;        //Giving Initial test data.
        volatile unsigned int srcAddr = 0x30000000;   //Source address
        Xil_Out32(srcAddr, u32TestData);    //copy a data to main memory with physical address.
        //copy the data into a BRAM through CDMA
        Xil_Out32(XPAR_AXICDMA_0_BASEADDR + XAXICDMA_SRCADDR_OFFSET, (INTPTR)u32TestData);
        //with this code, I can read right data from the BRAM.
        Xil_Out32(XPAR_AXICDMA_0_BASEADDR + XAXICDMA_SRCADDR_OFFSET, srcAddr);
        //but this code stores some junk data in the BRAM.
Is there any mistake I made? I don't understant why above tow cases have different results.
ZC702 board, Vivado 2015.2, Standard alone(no Linux).
Thank you..
Re: Source address of CDMA
Are you sure the address srcAddr contains the data you want? This is the first thing I could investigate.
I found the problem and sloved it.
The data was in the cache not in the DDR3, so When I update the data, I could get right signals.
Thank you.
