wuchy143
Spartan 3AN Not Supported By EDK??
I'm trying to use the Spartan 3AN dev board with the XC3S700AN FPGA with EDK.(latest software 12.1) I start my embedded system in the ISE and then go over to the EDK and the Base System Builder says that my board is not supported. This can't be true??? Screen shot below.
-mike
barriet
This should help:
http://www.xilinx.com/support/answers/35623.htm (12.1 EDK - Some Xilinx Boards are missing from Base System Builder (BSB))
Cheers,
bt
barriet
This should help:
Cheers,
bt
wuchy143
Fantastic. Thanks!!
wuchy143
Hello Again,
I did exactly what it said to do on the page but still no change. I then tried all the other boards which I can choose from in the ISE. Once I go into the EDK it then says that it doesn't support any board. Much like the screen shot I posted but just different chips. What am I missing. I'm following the tutorial to the T? Could it be vista causing me issues? That's the only thing I can think of. :(
-mike
wuchy143
got it to work. Not really sure why. :) But it works.
barriet
I haven't reviewed the tutorial...
But it sounds like maybe you didn't restart XPS or the paths didn't line up.
== I see you got this to work while I'm typing but maybe this will help explain it or help others.
barriet
another pic
barriet
and another
wuchy143
Yup it should. Again. Thanks!
-mike
