ralphrmartin
Split a large block design into multiple smaller ones
I am doing a Pynq design, and the hardware side of it is just too large to comfortably fit into a single block design. Ideally, I'd like to refactor my block design into a top level design with blocks like processor, peripherals, etc, and then these in turn are implemented as further (sub)-block designs.
Is this possible at all? Is there an automatic refactoring tool to help me do this?
savula
Hi @ralphrmartin ,
one way you can use the create Hierarchy method. Please select the IPs in your BD design and then right click and select create Hierarchy and give a name. this will move the selected IPs into a single block and that single block only seen in main BD. if you doubble click on newly created Hierarchy then it will open the IPs in another page.
Best Regards,
Srikanth
savula
Hi @ralphrmartin ,
Best Regards,
Srikanth
ralphrmartin
Thanks for the tip. I'll try that.
