Standalone Microblaze examples or tutorials?
I am completely new to standalone microblaze, apart from the "hello world" example is there any tutorials or example c projects or free training I can use? I need to use interrupts, can bus, uart, timers and so on but there seems to be a shortage of tutorials on the software development.
I have a project from an ARM microcontroller that I would like to convert to microblaze.
thanks in anticipation
Dave
Re: Standalone Microblaze examples or tutorials?
You can find useful tutorials at http://www.fpgadeveloper.com/category/tutorials
 Timer with interrupts - http://www.fpgadeveloper.com/2008/10/timer-with-interrupts.html
 Read DIP switch from microbalze application - http://www.fpgadeveloper.com/2011/07/read-dip-switches-from-a-microblaze-application.html
Praveen
Praveen
Praveen,
Thanks for those, the switch read was a help.
Is that all there is by way of tutorials?
Yes, these are tutorials and good learning.
Praveen
