Standard C libraries - linker error
I'm getting "undefined reference to 'sqrtf'" errors from the linker.  This is a standard C99 library function with declaration in math.h.  I've tried adding "-std=c99" arguments to the gcc compile and link settings.  Do I need to add the standard C libraries to the project?
What else could be the problem?
Cheers
Can you post your c code that you would want to compile?
I see that this is already defined in math.h
extern float sqrtf _PARAMS((float));
Also please confirm which version of SDK you are using.
--Hem
Hem,
I'm using v2014.2.  The problem with posting the code is that I'm porting quite a large project with many source files.
Trying to produce some minimal code that shows the problem.  In the process so far I have found a couple of symptoms.
1. I get the same linker error when I change the function call to sqrt(), which is a C90 function.
2. I don't get the error if I remove it from the the file it is in, but call sqrtf() from main.c, the file that has main() in it.
3. Even with identical #include's I get the error for calls in 1 file, but not main.c.
4. It doesn't seem to be a name mangling problem, because I still get the error if I add the prototype "float sqrtf(float);" just before the function that calls it and gives the linker error.
5. The error is still there if I add libm.a to the project.
Still wracking my brain.
Steve
You can try with clean projects in SDK. Sometimes cleaning the libraries may help. It may be old libraries weren't updated correctly.
Thanks and Regards
Balkrishan
OK I've managed to produce a minimal setup that gives me the error.
SDK created the hardware from the attached .hdf file.  I created a brand new baremetal hello_world application project, allowing SDK to create a new BSP.  I added "#include <math.h>" and a function that calls sqrt() to hello_world.c (to get the attached hello_world.c).  Saved hello_world.s and ....boom.... I got the "undefined refernce" linker error.
The fact that I'm the only person having this problem suggests I must be doing something blindingly obviously wrong, I have a corrupted installation, or there's some incompatibility between v2014.2 and WinXP.
I'm still interested in somebody trying this out to see if they get this error.  Anyone?
Try this, I got it from a Zedboard/Vivado workshop tutorial I have been using:
Right-click on the “Your Project” project in the Project Explorer, and choose “C/C++ Build Settings”.
 Choose the “ARM gcc linker  Libraries” section.
 Click the “Add...” button in the “Libraries” pane at the top. (The button is the one with the green “+” sign on the document icon)
 Type “m” in the entry field and then click “OK”.
 Click “OK” to return to the main SDK window.
Thanks! your answer solved my problem!
