su.li@bd.com
Standard header files not found
When I created a C++ project and include some standard header files, such as iostream, fstream, stdio.h and iostream etc. I have the similar problem as this post:
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/SDK-can-not-find-header-files/td-p/562757
and tried the given suggestions. I also added the path C:\Xilinx\SDK\2018.2\gnu\aarch32\nt\gcc-arm-linux-gnueabi\arm-linux-gnueabihf\include\c++\7.2.1\tr1  but still shows the warning signs(see screen shot). Any one has a complete solution to resolve the issue? Thanks in advance!
su.li@bd.com
Actually after I checked GCC Build-in Compiler Settings Cross ARM, it works ok.
ibaie
Hi su.li@bd.com,
You need to set the include folder path within the project settings.
Once done the path should be listed within the project include directories and if the correct path the include statements should not be marked as non resolved.
Ibai
su.li@bd.com
