Strange debug behavior
I'm new to work with microblaze and to understand I started using the examples provided with libraries.
Actually I've a strange problem I'm unable to run properly IIC examples, every time I debug the same code the microblaze stops on a different line of code (like in a infinite loop).
I'm using the xiic_eeprom_example.c example code, as I cant start the IIC comunication I modify the code as the following
* Start the IIC device.
while(Status != XST_DEVICE_IS_STARTED)
Status = XIic_Start(&IicInstance);
if (IicInstance.IsStarted != 0)
Status = XST_DEVICE_IS_STARTED;
The while loop never exit upon I step into the XIic_Start function and execute step by step all assembly instructions, otherwise the function never starts the IIC device.
I can't understand this behavior, I'm using Vivado 2017.2 on a Kintex Ultrascale device
regards
