Support for Spartan2/2e removed in EDK9.1 from EDK8.1 in Base System Builder???
Here is something strange I noticed in EDK 8.1 and 9.1.
In the EDK 8.1 getting started guide it clearly states that Spartan2-class FPGAs are supported.
If you open base system builder and start entering parameters for a custom board at the 'Select Processor' MicroBlaze step you can choose Spartan2, 2e, etc as your target device.
However, do the same under EDK9.1, you will spartan2 is no longer available.
If you open the EDK documentation and look up supported processors, it states that Spartan2 is supported.
The program itself says otherwise.
the s2 support is removed only from BSB, the rest of the EDK still supports S2, so you need a little work manual work
Antti
