Synthesis problem of EDK project attached in the ISE 12.4
Xilinx Port::Process Exec Failed:2
ERROR:EDK -
   Error while running "gmake -f system.make netlist".
ERROR: synthesizing XPS module failed!
Process "XPS Process: Synthesize XPS Source" failed
Best wishes !
Re: Synthesis problem of EDK project attached in the ISE 12.4
Can you post your complete log and a snapshot of your ISE project view?
Newbie butchja
if you use linux - try to link make to gmake
sudo ln /usr/bin/make /usr/bin/gmake
greetz.
Observer kursadgol
Thank you. it works.
Visitor da_steve101
Thank You!!!!
Visitor maanrl
It works. I am using Mint 17. Thanks!
Solution worked perfectly. Thanks.
