TCF profiler for multi-threaded applications
Is it possible to get the TCF profiler to look at threads other than the main-thread for multi-threaded linux applications? As far as I can tell it is currently only analysing the main thread.
Mark
Hi Mark,
You need to start the profiler for each thread. You can plant a breakpoint at the entry and exit points of the threads, and when the thread is created, start the profiler. Please note that the profiler view is closed when the thread/context exits, so you need a BP at the end of the thread to analyze the results. I'm not aware if there is a way to save the results to a file
Hi Mark,
Great thanks
