TFT controller for virtex 5 XUPV5 LX110T
Hai.. I want to design TFT controller using EDK. How do i do it?? Can any1 tell me the steps or procedure???
Re: TFT controller for virtex 5 XUPV5 LX110T
Hi Harsha
Refer to http://www.xilinx.com/products/boards/ml505/ml505_11.1_1/docs/ml505_bsb_std_ip_addition.pdf
This has TFT with ML505 which is similar to XUPV5 board
--Hem
The below documents  are useful  reference material for your requirement
http://www.xilinx.com/products/boards/ml510/ml510_12.1/docs/ml510_bsb1_std_ip_addition.pdf
http://www.xilinx.com/products/boards/ml510/ml510_12.1/docs/ml510_bsb1_ppc440_std_ip_addition.pdf
Thank you :)
