xela_lin
The maximum capability of mali-400
We have a potential scenario described as below:
1. A system with predefined frame buffer with dimension (far) larger than maximum capability of mali-400.
2. The system receives arbitrary updating requests at any part of such frame buffer mentioned above.
3. Incoming requests are performed by mali-400.
4. The frame buffer will be split into multiple parts and output with multiple HDMI TX SS separately after updating.
I understand mali-400 cannot perform such task at once. I wonder if multiple zynq configuration could satisfy this need?
If the answer is 'Yes', how zynqs share and exchange data among them? Can you suggest any suitable idea?
