medha_design
Time to excute Microblaze instruction from external SPI flash
In Using SIP Serial Flash reference design of Spartan-3E starter kit C_SCK_RATIO parameter of xps_spi peripheral is set to 64.
Does it mean the spi clock generated is 50MHz / 64 = ~781 KHz i.e.1.28 us to get a bit from SPI flash memory.
So to get 32 bits of microblaze instruction the time taken is ~33 us.
Please advice whether my assumption is correct OR not??
