Observer inform_won
Too many comps of type "RAMB16"... What does this mean??
I created a program utilizing the PPC, BRAM, LEDS in an ML403 evaluation board based on the following:
http://nonlinear.eecs.berkeley.edu/bharath/pubs/FPGA-Tools_HOWTO.pdf
While generating a bitstream to configure the FPGA board, I received the following errors. Can anyone help??
# Starting program map
# map -o system_map.ncd -pr b -ol high -timing system.ngd system.pcf
Release 10.1.01 - Map K.34 (nt)
Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved.
PMSPEC -- Overriding Xilinx file <>
with local file <>
Using target part "4vfx12ff668-10".
Mapping design into LUTs...
Writing file system_map.ngm...
Running directed packing...
Running delay-based LUT packing...
ERROR:Pack:2310 - Too many comps of type "RAMB16" found to fit this device.
ERROR:Map:115 - The design is too large to fit the device. Please check the
Design Summary section to see which resource requirement for your design
exceeds the resources available in the device. In particular check the
non-slice resources since the slice counts may reflect the early termination
of the flow.
NOTE: An NCD file will still be generated to allow you to examine the mapped
design. This file is intended for evaluation use only, and will not process
successfully through PAR.
Mapping completed.
See MAP report file "system_map.mrp" for details.
Problem encountered during the packing phase.
Design Summary
Number of errors : 2
Number of warnings : 3
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
Done!
Message Edited by inform_won on 06-29-2008 11:04 PM
Message Edited by inform_won on 06-29-2008 11:05 PM
Message Edited by inform_won on 06-29-2008 11:09 PM
Re: Too many comps of type "RAMB16"... What does this mean??
That means the BRAMs requirement exceeds what you have in your device. It dose not have enough BRAMs. Try to reduce the BRAM size.
Observer inform_won
I reduced the BRAM size to 32K, then it works. Thanks!
On a related note, I'm getting the same error, 20 minutes into a build when I use too many RAMB16s in a logic analyzer core.
It would be REALLY NICE if Xilinx could quickly analyze these core requirements in the beginning and either error soon, OR have a  setting to maximise RAMB16 in the logic analyzer, throw up  a notice and keep on building.
It sucks to wait 20 minutes only to find out there is an error.
