Transfer very large file via UART
I want to transfer a very large file (56 MB) to DRAM in FPGA Zynq UltraScale+. I will use UART for now with baud rate 115200.
I use TeraTerm but when I send the file I do not know when to start my application and start sending file from teraterm, so that will "catch" my file in serial port.
I have the following code to set the UART:
int initUart();
u8 ReadRawBytesFromImage();
u8 ReadRawBytesFromImage(){ u8 *image_buffer; int status=initUart(); if(status!=XST_SUCCESS){ xil_printf("Error initializing UART!\n"); } u32 bytes_received = XUartPs_Recv(&xuartps_0,image_buffer,XMAX*YMAX*SLICES); xil_printf("bytes received:%d\n",(int)bytes_received); return image_buffer; } int initUart(){ s32 status; /*xil_printf("Setting up UART!\n"); status = XUartPs_SetDataFormat(&xuartps_0, &xuarapsformat_0); if(status!=XST_SUCCESS){ xil_printf("Error setting up UART!\n"); return; }*/ xuartps_config_0 = XUartPs_LookupConfig(XPAR_XUARTPS_0_DEVICE_ID); if (NULL == xuartps_config_0) { return XST_FAILURE; } status = XUartPs_CfgInitialize(&xuartps_0,xuartps_config_0, xuartps_config_0->BaseAddress); if(status!=XST_SUCCESS){ return XST_FAILURE; } XUartPs_SetBaudRate(&xuartps_0, 115200); status = XUartPs_SelfTest(&xuartps_0); if (status != XST_SUCCESS) { return XST_FAILURE; } //int bytes_sent=send_finalbuffer(array); //printf("bytes sent=%d\n",bytes_sent); /*union {float C[XMAX*YMAX]; u8 C_micro[XMAX*YMAX];}sender; for(int i=0;i<XMAX*YMAX;i++) sender.C[i]=array[i]; u32 payload = XMAX*YMAX*8; status = XUartPs_Send(&xuartps_0,sender.C_micro, payload); if(status!=XST_SUCCESS){ xil_printf("\rError sending C in UART!\n\r"); return; }*/ return XST_SUCCESS; }
Do I have to use loop here? ---> u32 bytes_received =XUartPs_Recv(&xuartps_0,image_buffer,XMAX*YMAX*SLICES);
Is there any way to make the code blocking so that catch the file?
The baud rate is very low with UART, how can I set the ethernet to transfer the file?
Thank you in advance
You should use an Ethernet IP core at the data link layer.
Outside world --> Ethernet PHY --> Ethernet core --> FIFO --> DRAM Controller core --> DRAM.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
But how will I transfer the file via UART?
@kostas23
Even with your app synchronized with Tera Term, you'll likely encounter some bits in error transferring that amount of data over an UART.
You should consider using (implying adding it in your app) XMODEM, YMODEM or a likewise transfer protocol.
Tera Term supports XMODEM & YMODEM and the start-up synchronization is dealt with by the protocol.
XMODEM and YMODEM are fairly simple, small code (about 100-200 lines of "C"), and openly available.
