crono123
Trouble Generating a Linker Script
  I'm trying to create a new software application project in EDK 10.1.3 and when I try to generate a linker script I get this warning:
make -f system.make FSL_TestApp_program started...
make: *** No rule to make target `/cygdrive/c/Xilinx/FinalProjects/FSL_TestApp/FSL_TestApp_linker_script.ld', needed by `FSL_TestApp/executable.elf'.  Stop.
Done!
Any ideas would be appreciated and if I'm leaving out any pertinent details please let me know what I can supply.  Thanks.
crono123
Thanks for the tip.  It seems that EDK was not creating the directory needed for the software project.  After I made the directory, the tool generated the linker script in the appropriate location.  Things are good to go now.
vsiva
Did the linker script get generated? The error says that make couldn't find "FSL_TestApp_linker_script.ld". See if it is there in the location specified and if you can read it.
crono123
