aminfar1
Trying to remove DDR2 from XAPP1026
 I am trying to remove DDR2 IP from XAPP1026 XPS project files. I simply deleted the DDR2_SDRAM IP core and I then modified ucf file. The synthesis and P&R processes go well, but when I want to "Generate Libraries and BSPs" in XPS, i get the following error message.
Staging source files.
Running DRCs.
Runnning DRC for lwIP library...
lwIP can be used with the following EMAC peripherals found in your system:
Hard_Ethernet_MAC
ERROR:EDK - xget_handle  parent :  A NULL handle was provided
ERROR:EDK - lwip130 () - expected integer but got ""
MFS DRC ...
ERROR:EDK:1191 - Error(s) while running DRCs for processor microblaze_0.
make: *** [microblaze_0/lib/libxil.a] Error 2
Done!
Any ideas?
XPS 11.4, virtex-5, ML505/506, standalone OS library.
aminfar
vsiva
check your lwIP configuration in your MSS to see if you've enabled checksum offload in lwIP.
vsiva
That is a bug in the TCL code. IT should really say that the TEMAC's local link ports are not connected to anything.
So you cannot just remove mpmc and expect the design to work since the temac does not know where to put the incoming packets. You'd have to connect the ll interface to a difference ll sink (xps_ll_fifo or sdma).
aminfar1
Good catch! thanks!
Now I added a FIFO and connected its local link to MAC's local link, and I got the following error while generating libraries and BSPs.
Hard_Ethernet_MAC
ERROR:EDK:3193 - issued from TCL procedure "lwip_temac_channel_hw_drc" line 27
    lwip130 () - Checksum offload is possible only with a DMA engine
MFS DRC ...
Done!
So I unchecked two RX and TX "Checksum offlod for TEMAC" options in Ethernet MAC IP Core, I then resynthesized. But I still get the error above. Any thoughts?
vsiva
aminfar1
Thanks for your help. got fixed.
I am now trying to trim some functions of C programs in order to make the XAPP1026 code smaller. But it seems like that there is no way to fit lwIP on a 256KB on-chip memory. Has any one done that before? any idea?
naz56
hi
in SYSTEM.MSS file there is no option for enabling checksum.
BEGIN LIBRARY
 PARAMETER LIBRARY_NAME = lwip130
 PARAMETER LIBRARY_VER = 1.00.b
 PARAMETER PROC_INSTANCE = microblaze_0
 PARAMETER api_mode = SOCKET_API
END
