Scholar golson
Trying to use system clock as a external output port as well as internal clock signal
  I would like to send the System clock out of the Microblaze submodule.  I tried making the clock_generator_0 port CLK_OUT0 sys_clk_s net a external port.
I receive the following error.
  Make instance clock_generator_0 port CLKOUT0 external with net as port name
Can't make external port sys_clk_s_pin - net sys_clk_s already used
I think this is because the net is used all over the place and the port name may not be the same name as the signal.  How can I send the clock to a external output port?
Thank You,
  Gary Olson
Historian
Historian
Re: Trying to use system clock as a external output port as well as internal clock signal
Do you want the "external" clock to be external to the FPGA (brought to an I/O pin) or external to the MicroBlaze module but still inside the FPGA?
-a
Scholar golson
Still inside the FPGA but outside the Microblaze Submodule.  I would also want to send out a Reset Signal.
Are you trying to connect the output of the clock generator as an external port?
Scholar golson
Yes,  I am looking for a way to feed external logic not part of the Microblaze system.  but where a Microblaze submodule would share the system clock and reset with
external logic.
You can manually add it to the MHS
 PORT sys_clk_s_pin = sys_clk_s, DIR = O
Scholar golson
Thank You,
  Gary
