chriscorp
UART RECEIVE DATA AND SAVE INTO DDR
Newbie to microblaze, I am currently doing a project that needs to receive data from uartlie and save into DDR ram to processed later can anyone give me an example c code of doing that? I am using spartan board, the memory controller used is MPMC and uartlite is my stdio.
I have tried searching for it but most of them just teach how to process the data but not how to receive and save data into DDR, any simple example will do just wanna get started only.
Thanks in advance.
saranshmeh
// Here is code for writing only. parallel will be for reading.
// Initially what you can do is, you can pass a command byte sequence from UART, before passing data. Command sequence should include - reading or writing, and how much filesize to read ot write.
// here i am assuming to write to DDR2 only.
/ /ptr is base address of MPMC
// this is for writing to DDR2, where i am assuming the data width to be 32, and since uart works in 1 byte, so we will have //to concatenate while writing to it.
// real_file_size; is the file size you want to write to DDR2. If you want to write whole DDR2, then you need not pass it.
ptr=0x88000000;
            //xil_printf("\n\rWriting in Progress");
            for(i=1;i<=real_file_size;i++)
                j=(i-1)%4;
                data[j]=XUartLite_RecvByte(0x84000000);
                if (j==3)
                    data32=(data[0] | (data[1]<<8) | (data[2]<<16) | (data[3]<<24));
                    XIo_Out32(ptr,data32);
                    ptr=ptr+4;
                else if (i == real_file_size)
                    for (;j<=2;j++)
                        data[j+1] = 0;
                    ptr=ptr+4;
                    xil_printf("\n\rWriting in Progress %d",i);
            xil_printf("\n\rWriting Completed %d   %d ", i, real_file_size);
I think, this will provide you with sufficient idea as to how to proceed. Further you can proceed as to your application. Do let me know if this helps.
Saransh
saranshmeh
ptr=0x88000000;
                j=(i-1)%4;
                if (j==3)
                    ptr=ptr+4;
                    for (;j<=2;j++)
                        data[j+1] = 0;
                    ptr=ptr+4;
Saransh
v00d00
you can find examples in $xilinxinstalldirectory/version/EDK\sw\XilinxProcessorIPLib\drivers
here open folder of any ip  and find example c codes
hope this helps you
chriscorp
Thanks for your reply saranshmeh,
You code really helped me a lot!!!!
Thanks again!!.
Thanks for your reply also v00d00,
will look into your suggestion as well, thanks!!
lidianhao123
i do for follows:
"you can find examples in $xilinxinstalldirectory/version/EDK\sw\XilinxProcessorIPLib\drivers"
but i can find example c code can you tell detials.
Thank you in advance.
applistar
hi
UART RECEIVE DATA AND SAVE INTO DDR" very useful for me.real_file_size (you define the file size you want to write to DDR2 )you use in your code? Because the uartlite has buffer limited = 16 byte and if you transfer data to uart with so many data , buffer will full with data ==> wrong. I don't know you have a way to solve about this. Can you explain for me? Your post is help me very much . Thank you!
mahesr
hi everry body
I'm trying to implement the same on virtex 6. only changes are i'm using DDR3. rest all is same. but when i add the above code, which header files i have to add. please let me know. Do send me full c code and which header files to be added with it...
Thanks and looking for all your suggestions!!!!....
