jessekotsch
UART with Zybo Dev Board
I am trying to send data to a CPU using UART. I have exported Zynq periferals (UART) to PMOD connectors of the ZedBoard but I am not sure how to proceed! I have been trying to find a tutorial that walks you through how to use UART with this board but I cant find anything. Any help would be appreciated as I am really lost.
pvenugo
Hi @jessekotsch,
Make sure your hardware PS UART /AXI UART is routed to PMOD with appropriate pin constraints.
Once that is up and ready in system.mss of BSP you will see the UART IP listed. Later, create application based on use https://github.com/Digilent/ZYBO/blob/master/Projects/sdsoc/sdk/hello/src/helloworld.c to execute on UART IP to verify if it works.
Praveen
pvenugo
Hi @jessekotsch,
Praveen
jessekotsch
How do you verify that it works? Is there software I need on my computer to be able to read what is outputted using UART? This is the tutorial that I went through and I am lost as to what to do next since the tutorial just ends.
http://blog.idv-tech.com/2014/03/22/howto-export-zynq-peripheralsi2c-spi-uart-and-etc-to-pmod-connectors-of-zedboard-using-vivado-2013-4/
pvenugo
The link you shared tell about only hardware design.
Watch -> https://www.youtube.com/watch?v=GCRtGUyWyBM  for quick learning.
Praveen
