Uartlite interrupt vector in FreeRTOS
Hello.
I'm using ZCU102 board and uartlite IP in FreeRTOS.
It worked well in polling communication, but the problem is interrupt.
I receive the example code from google search as below and I modified a little.
* Copyright (C) 2002 - 2015 Xilinx, Inc.  All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* Use of the Software is limited solely to applications:
* (a) running on a Xilinx device, or
* (b) that interact with a Xilinx device through a bus or interconnect.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* XILINX  BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
* WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
* OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
* Except as contained in this notice, the name of the Xilinx shall not be used
* in advertising or otherwise to promote the sale, use or other dealings in
* this Software without prior written authorization from Xilinx.
* @file xuartlite_intr_tapp_example.c
* This file contains a design example using the UartLite driver and
* hardware device using the interrupt mode for transmission of data.
* @note
* None.
* <pre>
* MODIFICATION HISTORY:
* Ver   Who  Date	 Changes
* 1.00b sv   06/08/06 Created for supporting Test App Interrupt examples
* 2.00a ktn  10/20/09 Updated to use HAL Processor APIs and minor changes
*		      for coding guidelnes.
* 2.01a ssb  01/11/01 Updated the example to be used with the SCUGIC in
*		      Zynq.
* </pre>
/***************************** Include Files *********************************/
#include "xparameters.h"
#include "xuartlite.h"
#include "xil_exception.h"
#ifdef XPAR_INTC_0_DEVICE_ID
#include "xintc.h"
#include <stdio.h>
#else
#include "xscugic.h"
#include "xil_printf.h"
#endif
/************************** Constant Definitions *****************************/
 * The following constants map to the XPAR parameters created in the
 * xparameters.h file. They are defined here such that a user can easily
 * change all the needed parameters in one place.
#ifndef TESTAPP_GEN
#define UARTLITE_DEVICE_ID	  XPAR_UARTLITE_0_DEVICE_ID
#define UARTLITE_IRPT_INTR	 /*XPS_FPGA8_INT_ID*/XPAR_FABRIC_AXI_UARTLITE_0_INTERRUPT_INTR
#define INTC_DEVICE_ID		XPAR_INTC_0_DEVICE_ID
#else
#define INTC_DEVICE_ID		XPAR_SCUGIC_SINGLE_DEVICE_ID
#endif /* XPAR_INTC_0_DEVICE_ID */
#endif /* TESTAPP_GEN */
 * The following constant controls the length of the buffers to be sent
 * and received with the UartLite device.
#define TEST_BUFFER_SIZE		100
/**************************** Type Definitions *******************************/
#define INTC		XIntc
#define INTC_HANDLER	XIntc_InterruptHandler
#else
#define INTC		XScuGic
#define INTC_HANDLER	XScuGic_InterruptHandler
/***************** Macros (Inline Functions) Definitions *********************/
/************************** Function Prototypes ******************************/
int UartLiteIntrExample(INTC *IntcInstancePtr,
			XUartLite *UartLiteInstancePtr,
			u16 UartLiteDeviceId,
			u16 UartLiteIntrId);
static void UartLiteSendHandler(void *CallBackRef, unsigned int EventData);
static void UartLiteRecvHandler(void *CallBackRef, unsigned int EventData);
static int UartLiteSetupIntrSystem(INTC *IntcInstancePtr,
static void UartLiteDisableIntrSystem(INTC *IntrInstancePtr,
/************************** Variable Definitions *****************************/
 * The instances to support the device drivers are global such that they
 * are initialized to zero each time the program runs.
#ifndef TESTAPP_GEN
extern XScuGic xInterruptController;
//INTC IntcInstance = xInterruptController;	/* The instance of the Interrupt Controller */
static XUartLite UartLiteInst;  /* The instance of the UartLite Device */
#endif
 * The following variables are shared between non-interrupt processing and
 * interrupt processing such that they must be global.
 * The following buffer is used in this example to send data  with the UartLite.
u8 SendBuffer[TEST_BUFFER_SIZE];
 * The following counter is used to determine when the entire buffer has
 * been sent.
static volatile int TotalSentCount;
* Main function to call the UartLite interrupt example.
* @param	None.
* @return	XST_SUCCESS if successful, else XST_FAILURE.
* @note		None.
#ifndef TESTAPP_GEN
int main(void)
	int Status;
	 * Run the UartLite Interrupt example , specify the Device ID that is
	 * generated in xparameters.h.
	Status = UartLiteIntrExample(&xInterruptController,
				 &UartLiteInst,
				 UARTLITE_DEVICE_ID,
				 UARTLITE_IRPT_INTR);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	else
			xil_printf("example complete\n");
	while(1);
	return XST_SUCCESS;
#endif
* This function does a minimal test on the UartLite device and driver as a
* design example. The purpose of this function is to illustrate how to use
* the XUartLite component.
* This function sends data through the UartLite.
* This function uses the interrupt driver mode of the UartLite.  The calls to
* the  UartLite driver in the interrupt handlers, should only use the
* non-blocking calls.
* @param	IntcInstancePtr is a pointer to the instance of INTC driver.
* @param	UartLiteInstPtr is a pointer to the instance of UartLite driver.
* @param	UartLiteDeviceId is the Device ID of the UartLite Device and
*		is the XPAR_<UARTLITE_instance>_DEVICE_ID value from
*		xparameters.h.
* @param	UartLiteIntrId is the Interrupt ID and is typically
*		XPAR_<INTC_instance>_<UARTLITE_instance>_VEC_ID value from
*		xparameters.h.
* @return	XST_SUCCESS if successful, otherwise XST_FAILURE.
* @note		None.
* This function contains an infinite loop such that if interrupts are not
* working it may never return.
			XUartLite *UartLiteInstPtr,
			u16 UartLiteIntrId)
	int Status;
	u32 Index;
	 * Initialize the UartLite driver so that it's ready to use.
	Status = XUartLite_Initialize(UartLiteInstPtr, UartLiteDeviceId);
		return XST_FAILURE;
	else
		xil_printf("uartlite init\n");
	 * Perform a self-test to ensure that the hardware was built correctly.
	Status = XUartLite_SelfTest(UartLiteInstPtr);
		return XST_FAILURE;
	else
		xil_printf("selftest\n");
	 * Connect the UartLite to the interrupt subsystem such that interrupts
	 * can occur. This function is application specific.
	Status = UartLiteSetupIntrSystem(IntcInstancePtr,
					 UartLiteInstPtr,
					 UartLiteIntrId);
		return XST_FAILURE;
	else
		xil_printf("setup intr system\n");
	 * Setup the handlers for the UartLite that will be called from the
	 * interrupt context when data has been sent and received,
	 * specify a pointer to the UartLite driver instance as the callback
	 * reference so the handlers are able to access the instance data.
	XUartLite_SetSendHandler(UartLiteInstPtr, UartLiteSendHandler,
							 UartLiteInstPtr);
	XUartLite_SetRecvHandler(UartLiteInstPtr, UartLiteRecvHandler,
							 UartLiteInstPtr);
	 * Enable the interrupt of the UartLite so that the interrupts
	 * will occur.
	XUartLite_EnableInterrupt(UartLiteInstPtr);
	xil_printf("enable intr\n");
	return XST_SUCCESS;
* This function is the handler which performs processing to send data to the
* UartLite. It is called from an interrupt context such that the amount of
* processing performed should be minimized. It is called when the transmit
* FIFO of the UartLite is empty and more data can be sent through the UartLite.
* This handler provides an example of how to handle data for the UartLite, but
* is application specific.
* @param	CallBackRef contains a callback reference from the driver.
*		In this case it is the instance pointer for the UartLite driver.
* @param	EventData contains the number of bytes sent or received for sent
*		and receive events.
* @return	None.
* @note		None.
	TotalSentCount = EventData;
* This function is the handler which performs processing to receive data from
* the UartLite. It is called from an interrupt context such that the amount of
* processing performed should be minimized. It is called when any data is
* present in the receive FIFO of the UartLite such that the data can be
* retrieved from the UartLite. The amount of data present in the FIFO is not
* known when this function is called.
* @param	CallBackRef contains a callback reference from the driver,
*		in this case it is the instance pointer for the UartLite driver.
* @return	None.
* @note		None.
u8 chr;
	xil_printf("intr");
//	 XUartLite_Recv(&UartLiteInst,chr,1);
	 chr= XUartLite_RecvByte(XPAR_UARTLITE_0_BASEADDR);
	xil_printf("received char %c \r",chr);
* This function setups the interrupt system such that interrupts can occur
* for the UartLite. This function is application specific since the actual
* system may or may not have an interrupt controller. The UartLite could be
* directly connected to a processor without an interrupt controller. The
* user should modify this function to fit the application.
*		XPAR_<UARTLITE_instance>_DEVICE_ID value from xparameters.h.
*		value from xparameters.h.
* @note		None.
				u16 UartLiteIntrId)
	int Status;
#ifndef TESTAPP_GEN
	XScuGic_Config *IntcConfig;
	  Xil_ExceptionInit();
	 * Initialize the interrupt controller driver so that it is ready to
	 * use.
	IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
	if (NULL == IntcConfig) {
		return XST_FAILURE;
	else
		xil_printf("lookup\n");
	Status = XScuGic_CfgInitialize(IntcInstancePtr, IntcConfig, IntcConfig->CpuBaseAddress);
		return XST_FAILURE;
	else
		xil_printf("CfgInit\n");
	//XScuGic_SetPriorityTriggerType(IntcInstancePtr, UartLiteIntrId, 0xA0, 0x3);
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT, (Xil_ExceptionHandler)INTC_HANDLER, IntcInstancePtr);
	 * Connect the interrupt handler that will be called when an
	 * interrupt occurs for the device.
	Status = XScuGic_Connect(IntcInstancePtr, UartLiteIntrId, (Xil_ExceptionHandler)XUartLite_InterruptHandler, UartLiteInstPtr);
		return Status;
	else
		xil_printf("connect\n");
	 * Enable the interrupt for the Timer device.
	XScuGic_Enable(IntcInstancePtr, UartLiteIntrId);
#ifndef TESTAPP_GEN
	 * Register the interrupt controller handler with the exception table.
	 * Enable exceptions.
	//Xil_ExceptionEnable();
	Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ);
			xil_printf("exception enable\n");
	return XST_SUCCESS;
* This function disables the interrupts that occur for the UartLite.
* @param	IntcInstancePtr is a pointer to the instance of the INTC driver.
* @return	None.
* @note		None.
static void UartLiteDisableIntrSystem(INTC *IntcInstancePtr,
					  u16 UartLiteIntrId)
	 * Disconnect and disable the interrupt for the UartLite.
	XIntc_Disconnect(IntcInstancePtr, UartLiteIntrId);
#else
	XScuGic_Disable(IntcInstancePtr, UartLiteIntrId);
	XScuGic_Disconnect(IntcInstancePtr, UartLiteIntrId);
#endif
In main function, I enabled infinite loop (while(1);). So, When I pause this code, It is at while(1); in debug mode.
This is a natural outcome.
At this time, I paused this code after sent some data through uartlite to ZCU102 board from my desktop.
Then, the code was paused at vector table : 0x280 in port_asm_vectors.s file.
Please Look below code.
* Copyright (C) 2014 - 2018 Xilinx, Inc. All rights reserved.
 * Copyright (C) 2017 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy of
* this software and associated documentation files (the "Software"), to deal in
* the Software without restriction, including without limitation the rights to
* use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
* the Software, and to permit persons to whom the Software is furnished to do so,
* subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software. If you wish to use our Amazon
* FreeRTOS name, please do so in a fair use way that does not cause confusion.
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* http://www.FreeRTOS.org
* http://aws.amazon.com/freertos
* 1 tab == 4 spaces!
* @file asm_vectors.s
* This file contains the initial vector table for the Cortex A53 processor
* Currently NEON registers are not saved on stack if interrupt is taken.
* It will be implemented.
* <pre>
* 5.00	pkp	5/21/14 Initial version
* </pre>
* @note
* None.
.org 0
.text
.globl _boot
.globl _vector_table
.globl _freertos_vector_table
.globl FIQInterrupt
.globl IRQInterrupt
.globl SErrorInterrupt
.globl SynchronousInterrupt
.org 0
.section .vectors, "a"
_vector_table:
.set	VBAR, _vector_table
.org VBAR
	b	_boot
.org (VBAR + 0x80)
	b	.
.org (VBAR + 0x100)
	b	.
.org (VBAR + 0x180)
	b	.
.org (VBAR + 0x200)
	b	.
.org (VBAR + 0x280) // It paused here.
	b	.
.org (VBAR + 0x300)
	b	.
.org (VBAR + 0x380)
	b	.
.org (VBAR + 0x400)
	b	.
.org (VBAR + 0x480)
	b	.
.org (VBAR + 0x500)
	b	.
.org (VBAR + 0x580)
	b	.
.org (VBAR + 0x600)
	b	.
.org (VBAR + 0x680)
	b	.
.org (VBAR + 0x700)
	b	.
.org (VBAR + 0x780)
	b	.
 * Vector table to use when FreeRTOS is running.
.set	FREERTOS_VBAR, (VBAR+0x1000)
.org(FREERTOS_VBAR)
_freertos_vector_table:
	b	FreeRTOS_SWI_Handler
.org (FREERTOS_VBAR + 0x80)
	b	FreeRTOS_IRQ_Handler
.org (FREERTOS_VBAR + 0x100)
	b	.
.org (FREERTOS_VBAR + 0x180)
	b	.
.org (FREERTOS_VBAR + 0x200)
.org (FREERTOS_VBAR + 0x280)
.org (FREERTOS_VBAR + 0x300)
	b	.
.org (FREERTOS_VBAR + 0x380)
	b	.
.org (FREERTOS_VBAR + 0x400)
	b	.
.org (FREERTOS_VBAR + 0x480)
	b	.
.org (FREERTOS_VBAR + 0x500)
	b	.
.org (FREERTOS_VBAR + 0x580)
	b	.
.org (FREERTOS_VBAR + 0x600)
	b	.
.org (FREERTOS_VBAR + 0x680)
	b	.
.org (FREERTOS_VBAR + 0x700)
	b	.
.org (FREERTOS_VBAR + 0x780)
	b	.
.org (FREERTOS_VBAR + 0x800)
SynchronousInterruptHandler:
	stp	X0,X1, [sp,#-0x10]!
	stp	X2,X3, [sp,#-0x10]!
	stp	X4,X5, [sp,#-0x10]!
	stp	X6,X7, [sp,#-0x10]!
	stp	X8,X9, [sp,#-0x10]!
	stp	X10,X11, [sp,#-0x10]!
	stp	X12,X13, [sp,#-0x10]!
	stp	X14,X15, [sp,#-0x10]!
	stp	X16,X17, [sp,#-0x10]!
	stp     X18,X19, [sp,#-0x10]!
	stp     X29,X30, [sp,#-0x10]!
	ldp     X29,X30, [sp], #0x10
        ldp     X18,X19, [sp], #0x10
	ldp	X16,X17, [sp], #0x10
	ldp	X14,X15, [sp], #0x10
	ldp	X12,X13, [sp], #0x10
	ldp	X10,X11, [sp], #0x10
	ldp	X8,X9, [sp], #0x10
	ldp	X6,X7, [sp], #0x10
	ldp	X4,X5, [sp], #0x10
	ldp	X2,X3, [sp], #0x10
	ldp	X0,X1, [sp], #0x10
	eret
IRQInterruptHandler:
	bl      IRQInterrupt
	eret
FIQInterruptHandler:
        bl      FIQInterrupt
	eret
SErrorInterruptHandler:
        bl      SErrorInterrupt
	eret
.end
The problem is the 0x280 has no functions.
I think it has to enter to the _freertos_vector_table : 0x280 not _vector_table : 0x280, because _freertos_vector_table : 0x280 has 'FreeRTOS_IRQ_Handler'.
What is difference between '_freertos_vector_table' and '_vector_table'?
And why it pause at '_vector_table : 0x280'?
* ps.  Uartlite interrupt (this code) worked well when I modified port_asm_vectors.s file to that the '_vector_table : 0x280' has 'FreeRTOS_IRQ_Handler' like as below.
.org (VBAR + 0x280)
