Unable to Modify _Bool in XSDK > Expression window
I am using Xilinx SDK v2018.2 and I am unable to modify a bool (aka _Bool) value in the Expression window.  It seems like it should be possible to modify a bool value in the Expression window as it is possible to modify values of other types in the Expression window.
To replicate this issue:
1) Add the following to any *.c file:
#include <stdbool.h>
bool g_test = false;
2) Debug the project.
3) Add g_test to the Expression window.
4) Attempt to modify g_test in the Expression window.
Could the ability to modify bool values in XSDK > Expression window be enabled?  Presently, I have to look up the value in Memory and modify it there, which is a lot more cumbersome that being able to modify it in the Expression window.
Best Regards,
Joseph
P.S. In case it is relevant, I am using an Ultra96 hardware target.
Re: Unable to Modify _Bool in XSDK > Expression window
Hi @jchang_endiag
You are right, boolean values cannot be modified neither within Expression or Variable windows. Not sure if this a Xilinx related limitation or more Eclipse based but will check it internally.
Ibai
Ibai
