Unable to debug the data in ddr while using xsct tool while os running in zcu102 board
Hello
I want to debug the data, which is written into ddr using applocation.
Iam using xsct tool to debug it, but it is throughing an error while reading when an os is running in the board.
Iam using ZCU102 Evaluatuion baord.
Xsct is not thorowing any king of error when fsbl application is running.
Can any one please help me to solve this problem.I want to debug the data in ddr while os is running in it.
stephenm
What OS? Linux, or an RTOS?
If linux, then you would need to remove the cpu idling
https://www.xilinx.com/support/answers/69143.html
You can also add a watch window in SDK if you want to monitor a memory region.
Hii
But i have already disabled the CPU_IDLE boot argument in the u-boot.
Are there any other reasons for that error?
Thankyou
stephenm
Can you access this address wothout the OS running? ie you just program the PSU (either using the psu_init.tcl, or the fsbl)
I would just use the watch window in SDK. It is safer
yes iam able to read the registers without os ie. with fsbl, but iam getting this errror message when i bringup os.
