sagar8446
Unable to find Linux system root path
I want to run my application with linux. So, I created a new application project in sdk 2016.4. In that i have choosen os platform as linux and i found the path for linux tool chain and but unable to find the linux system root.
I have created one petalinux project in that i'm unable to find the path of /build/linux/rootfs/stage.
Please help me out with this issue.
Thanks in advance.
ibaie
Hi @sagar8446,
Not sure if you are still dealing with this issue but definitivelly you don't need to set the Linux toolchain in the new project wizard window as the SDK include the linux toolchain by default.
Ibai
Ibai
sagar8446
Ok fine, so how to include the xilinx parameters in the project now. Its showing error for the xilinx parameters.
ibaie
Hi @sagar8446
What do you mean with xilinx parameters, xparameters.h file? If so that's only valid for standalone, not Linux userspace applications.
Ibai
Ibai
sagar8446
so how to build the application with petalinux if these parameters are valid for only standalone application.
ibaie
Hi @sagar8446,
Again what do you mean with "these paramenters"? xparameters.h?
Ibai
sagar8446
xparameters.h, xil_io.h these type of parameters
ibaie
Hi @sagar8446,
Ok, so basically those files are not used when you create a Linux application. That's because in Linux userspace applications does not work with physical memory and all accesses to the different devices are done through frameworks.
I will recommend you to read about linux application development in order to familiarize on it.
Ibai
Ibai
sagar8446
So how to start with linux applications and buidl them in petalinux.
ibaie
Hi @sagar8446,
You can create and compile in the petalinux workflow as documented in the user guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug1144-petalinux-tools-reference-guide.pdf#page=53
Additionally you can use the SDK to build and debug Linux applications and once you have everything ready you can deploy it either using petalinux or just copying to your rootfs/SDcard/...
https://www.xilinx.com/html_docs/xilinx2017_4/SDK_Doc/SDK_tasks/sdk_t_create_new_linux_appln.html?hl=linux
Ibai
Ibai
