r4space
Unable to find full path for "arm-xilinx-eabi-gcc"
I've seen many posts about a similar error from back in 2013 but no new information applicable today.
Error is self explanatory, and the reason is simply because arm-xilinx-eabi-gcc isn't installed on my system anywhere. Question is why not and how do I get it installed or is it retired and the #Enclustra demo I'm trying to follow is therefore just too outdated?
Details:
- System: Ubuntu 16.04 LTS 64bit
- SDK: 2017.4 installed per std Xilinx tool approach
- SDK started as stand alone after sourcing /opt/Xilinx/SDK/2017.4/settings64.sh
- Tutorial: #Enclustra Mars ZX2 PM3 reference design
watari
Hi @r4space
I suggest to use arm-linux-gnueabihf-gcc instead of arm-xilinx-eabi-gcc.
The meaning of "hf" on "arm-linux-gnueabihf-gcc" is that have hardware floating processing unit and its compiler compile source codes with fpu instraction.
Xilinx's Zynq family are consist of ARM Cortex-A9 or ARM Cortex-A53 and ARM Cortex-R5.
These cpus have hardware floating processing unit.
So, I say again. I suggest to use arm-linux-gnueabihf-gcc instead of arm-xilinx-eabi-gcc to resolve this issue.
Best regards,
r4space
Thanks!  That's good to know actually.
Sounds like my problem is with a failing reference design then not a change in Xilinx tool chain.  I'll dig into the make files.
watari
Hi @r4space
Could you execute the following command before "source <...>/settings64.sh" ?
$ export CROSS_COMPILE=arm-linux-gnueabihf-
Best regards,
ibaie
Hi @r4space
Not sure if you are still working on this issue but you will not find arm-xilinx-eabi-gcc in 2017.4 release.
arm-xilinx-eabi-gcc is the standalone CodeSourcery GCC compiler used for Zynq devices in the early stages. At least since 2017.1 the default toolchain is Linaro (arm-none-eabi-gcc) so the CodeSourcery toolchain was installed just as outdated toolchain. Since 2017.3 it's not even provided as it has been deprecated in the SDK tool.
Use Linaro toolchain (arm-none-eabi-gcc) instead of CodeSourcery one (arm-xilinx-eabi-gcc).
Ibai
Ibai
