serge.kubera@ehb.be
Undefined refere,ce to ... (adding C and h files to my project)
I want to add some drivers to my XPS project (some C and H files).   In the past, I added the needed drivers into my project manualy (click on project > add existing files).  This did work nice.
Since I will experiment with drivers, and will have to change or add these drivers ...:  I wanne to try now by adding a reference to the library (click on project > Set compiler options > paths and options).
I added the directory in the field "Search paths > include".  The path is: C:/DOCUMENTEN/GUDI_1/XPS_projects/FIR_test_FSL/FIR_source/include  .... for me the path looks ok (No spaces) ... but I get the typical error "undefined reference..."
I've tried to do this before and read some of the numerous post on this problem ... but I never made it work (hence why I actualy added the files manualy).  So I don't understand how to add it.
thanks for any help,
Serge
mourad23
ca you help me to intrgrate a .h file
