Visitor jg-b
Undefined reference to pow despite linking to libm
I am experiencing some strange behaviour in Xilinx SDK 2018.2 with a Standalone OS project for A53.
I get "undefined reference to pow" and "undefined reference to log" errors despite including math.h and linking to libm as well. Weird thing is, that references to sqrt and powf do work.
Any ideas?
Jürgen
Scholar ericv
Re: Undefined reference to pow despite linking to libm
@jg-b
Looks like you have to move -lm after --start-group - likely one of the lib refers to pow() & log() and, libm not located between --start-group / --end-group, the linker doesn't re-scan libm.
Visitor jg-b
Thank you for the hint.
Alas the AR you are referring to suggests linking to libm.
As I already mentioned, that I did in the first place.
You have the math library linked, but not added (this is what the AR is trying to convey)
I took a simple example (as shown below), this failed if the math library wasnt added:
To fix this, I right clicked on the app, and choose C/C++ Build Settings, and added the math library as shown:
This built successfully:
Visitor jg-b
OK, sorry for the misunderstanding, added vs. linked, and thank you for clarifying.
Actually the settings in my project look just the same as yours, though, so libm is actually added, together with a custom library.
Scholar ericv
@jg-b
Visitor jg-b
That indeed did the trick.
Thank you.
