Update Bitsream with Processor Data does not work
I have an ISE 11.5 project that includes an EDK project as one its its modules.  What is the proper way to update the bitstream with the MicroBlaze software?  I've read that ISE automatically updates the bitstream during the regular build, but do I have to re-build the entire design every time the SW changes?  In my case I changed the SW and hitting the Generate Programming File does not seem to update the bitstream with the new SW, but clicking the UPDATE BITSREAM with Processor Data does not work either.  The latter just tries to execute the initbram command of the EDK project, but that does not work because implementation\download.bit does not exist (the bitstream is created in ISE).
Is there some step or setup that needs to be done?
Hey
I use ise 14.4 to create a system who have microblaze processor I search a way to ewport the bitsream but I did'nt found when I run XPS 14.4 in Hardware Generate bitsream is unavailable there is only generate netlist.
Do you have an idea ?
