Visitor moshonkatz
Update Microblaze IP-Core
Im using ISE and EDK version 13.4 With microblaze.
The microblaze IP-Core that comes With EDK ver 13.4 is 8.2b.
In the middle of my project I see that I need the sleep/Wakeup feature in microblaze, but from What I've seen it is not present in version 8.2b of microblaze.
I also have a license for ISE and EDK 14.7 Which comes With microblaze 8.5c that (from What I can see) has the sleep/Wakeup features.
I Would like to continue using ISE/EDK ver 13.4 for my project (I have a big project that does not contain only a soft core processor and changeing an ISE version is too big of a change for me), but update the microblaze IP-Core to 8.5c (or neWer). Is there a Way I can do this? if so, hoW?
Thnaks in advance.
Re: Update Microblaze IP-Core
It is not recommended to use Microblaze 8.5c in 13.4 as the version is not test with this version of IP.
I would suggest you to upgrade the 13.4 project to 14.7 directly. The tool will auto update IPs to 14.7 without much effort.
Praveen
