patcher33
Updatemem makes NOTHING
updatemem in 2017.3 seems to ignore all arguments and makes nothing.
It is a log output:
# updatemem v2017.3 (64-bit)
# SW Build 2018833 on Wed Oct  4 19:58:22 MDT 2017
# Start of session at: Wed Jan 31 22:56:12 2018
# Process ID: 7120
# Current directory: C:/FPGA/fm1_17.3/fpga/E23_ZX1PE1
# Command line: updatemem.exe -mode batch -source C:/hwdt/Xilinx/SDK/2017.3/scripts/updatemem/main.tcl -notrace -tclargs -meminfo data_rom.mmi -data test_rom.mem -proc dummy -bit system_top.bit -out e23.bit -force -debug
# Log file: C:/FPGA/fm1_17.3/fpga/E23_ZX1PE1/updatemem.log
# Journal file: C:/FPGA/fm1_17.3/fpga/E23_ZX1PE1\updatemem.jou
and the same in the journal.
I would await "Loading bitfile ..." and so on - but it makes nothing, also no error reports.
Any ideas?
patcher33
write_mmi.tcl seems to produce a wrong MMI file.
After the manual modification of the MMI file, the RAM content update works as desired. The correct MMFile for my design:
<?xml version="1.0" encoding="UTF-8"?>
<MemInfo Version="1" Minor="0">
  <Processor Endianness="Little" InstPath="/CPU/processing_system7_1">
  <AddressSpace Name="data_rom" Begin="1073741824" End="1073750015">
      <BusBlock>
        <BitLane MemType="RAMB32" Placement="X2Y25">
          <DataWidth MSB="17" LSB="0"/>
          <AddressRange Begin="0" End="2047"/>
          <Parity ON="false" NumBits="0"/>
        </BitLane>
      </BusBlock>
      <BusBlock>
        <BitLane MemType="RAMB32" Placement="X3Y25">
          <DataWidth MSB="31" LSB="18"/>
        </BitLane>
      </BusBlock>
	</AddressSpace>
  </Processor>
<Config>
  <Option Name="Part" Val="xc7z030fbg676-2"/>
</Config>
</MemInfo>
 updatemem output:
updatemem -mode batch -meminfo data_rom.mmi -data test_rom.mem -proc /CPU/processing_system7_1 -bit system_top.bit -out output.bit -force -debug
****** updatemem v2017.3.1 (64-bit)
  **** SW Build 2035080 on Fri Oct 20 14:20:01 MDT 2017
  **** IP Build 2034413 on Fri Oct 20 15:56:25 MDT 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
source C:/hwdt/Xilinx/Vivado/2017.3/scripts/updatemem/main.tcl -notrace
Command: update_mem -meminfo data_rom.mmi -data test_rom.mem -proc /CPU/processing_system7_1 -bit system_top.bit -out output.bit -force -debug
Dump the BRAM Initialization Strings.
Loading bitfile system_top.bit
Loading data files...
Updating memory content...
Creating bitstream...
Writing bitstream output.bit...
0 Infos, 0 Warnings, 0 Critical Warnings and 0 Errors encountered.
update_mem completed successfully
update_mem: Time (s): cpu = 00:00:15 ; elapsed = 00:00:15 . Memory (MB): peak = 522.543 ; gain = 468.465
INFO: [Common 17-206] Exiting updatemem at Tue Feb  6 08:30:51 2018...
ibaie
Hi @patcher33,
What does mean do nothing? I mean does it get's stuck or not output file generated?
Ibai
Ibai
stephenm
Can you share the mmi? How was the mmi created?
Why are you using the -proc as dummy, this should match the instpath in the mmi.
Does the mem data fall within the address range pointed to by the -proc?
You mem should have something like
@0
deadbeef
So updatemem will look in mmi for a valid range.
So, check the -proc matches the instpath, and check mem data falls within region in your mmi
patcher33
you are right - "-proc dummy" was wrong. I changed it to /CPU/processing_system7_1, but updamemem still makes nothing.
the MMI file was created by write_mmi.tcl from Xilinx web page. MMI content:
It is the MMI file:
  <AddressSpace Name="data_rom" Begin="0" End="8191">
      <BusBlock>
        <BitLane MemType="RAMB32" Placement="X2Y31">
        </BitLane>
      </BusBlock>
    </AddressSpace>
  </Processor>
<Config>
</Config>
</MemInfo>
As i can see the "AddressSpace" of the AddressRange both begins at 0, but the physical address of the AXI-BRAM controller is 0x40000000. The entries in the MEM files begin also @0.
Is it OK?
patcher33
      <BusBlock>
        </BitLane>
      </BusBlock>
      <BusBlock>
        </BitLane>
      </BusBlock>
	</AddressSpace>
  </Processor>
<Config>
</Config>
</MemInfo>
 updatemem output:
