elrond9999
Updating Hardware platform breaks bsp
Sometimes (not always) when exporting a new hdf from vivado to sdk the bsp does not update properly (some files are incomplete or missing). The only way I've managed to solve it is creating a new application project and a new bsp, which brings another problem. Sometimes SDK reports that the hardware platform is missing but if you try again (one to ten times...) it creates the application project properly.
Best Regards.
ibaie
Hi @elrond9999,
If you want the community be more responsive to your posts you should provide bit more information about your case. I mean, SDK release version, log files generated by the tool...
That way you might have better response and likely solve your issues :)
Ibai
Ibai
maps-mpls
Mentor
Mentor
Always close SDK before exporting your design to SDK.  After you open up SDK, regenerate your BSPs.
*** Destination: Rapid design and development cycles ***
