Observer yohboy
Using ARMCC with SDK - ERROR FSBL
I'm trying to use ARMCC with SDK and my zynq. I saw I can change the preference in "Toolchain Preferences" an change Cortex-a9 : Linaro to ARMCC. I set my system path and license for ARMCC, create an hello world application for zynq, compile, exec ... So far so good.
However, when I try to add a FSBL (New application Project -> Zynq FSBL), the FSBL BSP library compiles correctly but the FSBL fails. I get an error with the "fsbl_handoff.S" :
"../src/fsbl_handoff.S", line 1 (column 8): Error: A1163E: Unknown opcode __GNUC__ , expecting opcode or Macro
    1 00000000 #ifdef __GNUC__
"../src/fsbl_handoff.S", line 2: Error: A1167E: Invalid line start
    2 00000000 /******************************************************************************
"../src/fsbl_handoff.S", line 33: Error: A1167E: Invalid line start
   33 00000000 /*****************************************************************************/
"../src/fsbl_handoff.S", line 34: Error: A1167E: Invalid line start
   34 00000000 /**
"../src/fsbl_handoff.S", line 56 (column 8): Error: A1163E: Unknown opcode FsblHandoffJtagExit , expecting opcode or Macro
   56 00000000 .globl FsblHandoffJtagExit
"../src/fsbl_handoff.S", line 58 (column 8): Error: A1163E: Unknown opcode FsblHandoffExit , expecting opcode or Macro
   58 00000000 .globl FsblHandoffExit
"../src/fsbl_handoff.S", line 60: Error: A1167E: Invalid line start
   60 00000000 .section .handoff,"axS"
Do you have any input to fix this error please ?
SDK version: 2017.3
ARMCC version : 5
Thank you,
Best regards,
Yohan
Scholar ericv
Re: Using ARMCC with SDK - ERROR FSBL
@yohboy
the problem is the ARM asm does not recognizes the #ifdef , #elif.  The GNU assembler runs the pre-processor on assembly files before running the assembler itself. Ideally all you would need is to run the ARMCC pre-processor on the file but it also defines __GNU__  So either you delete the non-ARMCC code or you replace the #if #elif etc with these:
   IF (:DEF: __GNUC__)
  ELIF (:DEF: __IASMARM__)
  ELSE
  END
Make sure to not put these in the first column because the assembler will interpret them as labels.
Scholar ericv
@yohboy
The ARMCC compiler is GNU compatible but the assembler is not.  The errors you are getting are with the  assembly files because the ARM assembler syntax is not compatible with GNU's syntax.
To get them to build, you'll have to migrate the assembly files to the ARM syntax.
Observer yohboy
Hello @ericv,
Thank you for answer, I understand ARM assembler syntax is not comptatible with GNU assembler syntax, however, the FSBL seems to define different syntaxes (__GNU__ , __IASMARM__ , other...).
I was thinking it'll work !
You can find attack the fsbl_handoff.S for information.
Thank you,
regards, Yohan
Scholar ericv
@yohboy
   IF (:DEF: __GNUC__)
  ELSE
  END
Observer yohboy
Hi @ericv, thank you for help, it works perfectly !
regards,
Yohan
