Using C++ containers (e.g. "array", "list", "set", "map") in ARM9 application
I've tried to use C++ containers like array, map, set, etc. in my ARM9 application, but it seems that they aren't supported.
At least theirs headers aren't recognized by SDK.
Would it be possible to add container support in Xilinx SDK.
Thanks in advance.
Re: Using C++ containers (e.g. "array", "list", "set", "map") in ARM9 application
Bare metal, or under Linux?
A lot of the C++ libraries require an operating system, because they rely on that to manage dynamic memory allocation (among other things).
For the moment Bare metal
I have created a sample array c++ application for ZC706_hw_platform and it worked fine
#include <string>
#include <iterator>
#include <iostream>
#include <algorithm>
#include <array>
int main()
std::array<int, 3> a1{ {1, 2, 3} }; // double-braces required in C++11 (not in C++14)
std::array<int, 3> a2 = {1, 2, 3}; // never required after =
std::array<std::string, 2> a3 = { std::string("a"), "b" };
std::sort(a1.begin(), a1.end());
std::reverse_copy(a2.begin(), a2.end(),
std::ostream_iterator<int>(std::cout, " "));
std::cout << '\n';
for(const auto& s: a3)
std::cout << s << ' ';
Have you tried something similar?
