dag1
Using EDK to Run Xilkernel on a MicroBlaze Processor
The document
http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_3/ug758.pdf
shows
a Xilinx embedded system example design that illustrates the features of the Xilkernel on the MicroBlaze soft processor, using the Embedded Development Kit. It uses the  ML507 Evaluation Platform board
I only have the Spartan 3e and Spartan 6 evaluation boards. Can I still implement this example ?
thanks
Dag
elzinga
You can build a design on your target platform based off of the ML507 design.  Make sure your hardware matches a closely as possible to the one described in the ML507 design and make sure your MSS (in particular, the Xilkernel OS settings) match.
claesvincent
check http://pwo.fpga.be
Click on "Course Material" --> then on this page "Implementation of Xilkernel on Spartan3E Starter board".
Kind regards
Vincent Claes
