dje666
Voyager
Voyager
Using Jenkins Automation Server to build xSDK ( xSCT) projects
Dear Forum,
Is it possible to build xSDK projects using the xSCT tools in the Jenkins Automation-Server?
Can anyone point me to examples?
DJE666
ibaie
Hi @dje666
The UG1208 provides several examples of XSCT scripts that can be adapted for your particular requirements so creating the TCL script that automates a build with XSCT by itself should be easy.
In the Jenkins side I'm not really familiar but my idea is that it should be quite straight away you just need to run "xsct <script>" on your shell.
Ibai
ibaie
Hi @dje666
Ibai
