tuan94@
Using SDK,VIVADO 2018.3
Hi Everyone,
My question is,
How to using SDK,but dont need the Board.
I am using FPGA at7 35 board,but i want to know.How to me can use SDK but dont need the Board
Thank you for your help,
tuan,
ibaie
Hi tuan94@,
I'm not sure about which board are you talking about but in overall you don't need a board to use neither Vivado or SDK for development process. Of course if you don't have any board you will not be able to debug/run the application on the target.
Depending the use case you might be able to use QEMU simulator to emulate the processor but with some limitation specially if you are facing a microblaze design on your FPGA.
Ibai
ibaie
Hi tuan94@,
Ibai
