petra_csereoka
Using Tcl scripts in SDK - Linker Script generation
Currently, I am trying to write a tcl script to fully automate the proces of project generation, linker script generation and downloading the binary to the fpga board in SDK. But I got stuck at the linker script generation.
I was wondering if it is possible to generate the linker script from tcl script.
And especially setting some parameters like stack and heap size.
All I found was:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/SDK_Doc/SDK_concepts/sdk_c_batch_mode.html
But nothing yet related to linker script.
Any help is very appreciated.
pedro_uno
Advisor
Advisor
Have you made any progress with this effort?
I also want to automate XSDK workspace setup for a Zynq project. I made some progress using XSCLT but I have run into a road block when it comes to specifying a link library.  I need libm to do some floating point trigonometry functions.  I have not determined how to specify link libraries in an XSCLT script.
I also want to create a run configuration but do not see a way to script that either.
    Pete
DSP in hardware and software
