ssjha
Using Vitis without ubuntu
I want to use Vitis on windows alone environment without even having ubuntu vm. I see that for almost all ubuntu vm seems a must. how to work with Vitis and flash on platforms like zynq 7000 using only windows components.
harahika
In my understanding, linux is required for the Petalinux toolchain if you're using that and not just bare metal. Lot of vendors have the VM image for their boards available and there are guides like this: https://www.hackster.io/news/microzed-chronicles-vitis-acceleration-creating-a-vm-setup-363946fb4ede
BR,
Harri
marcb
Hi @ssjha
It depends on what you want to do in Vitis. Page 20 from the Vitis Embedded Software Development User Guide (UG1400) indicates that Vitis Embedded is supported under Windows, but not the acceleration features.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug1400-vitis-embedded.pdf#page=20
ssjha
Thanks. I was looking for possibility of acceleration on windows environment without having to install ubuntu. I think this is a limitation then.
