jh0813
Using expression for changing and monitoring variables causes ISR to halt
Hi, I'm using ZYNQ zc702 (Zedboard) with Vivado SDK and now I'm designing a controller for the control of the power converter.
When I tried to control the converter, I found a problem that ISR doesn't work while changing and updating the variable on the expression window.
This problem is seriously critical to the system... It could make the converter destroying.
I think the same problem with these links,
https://forums.xilinx.com/t5/Embedded-Development-Tools/Refresh-Expressions-window/m-p/1024515
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-Debugging-Expressions-update-problem/m-p/1174968#M56388
https://forums.xilinx.com/t5/Embedded-Development-Tools/Accessing-global-variable-via-SDK-debugger-causes-ISR-to-halt/td-p/1092785
Unfortunately, there is no clear solution.
is this problem an inherent problem of this processor? I don't agree with this.
Because, I didn't find and see this kind of problem when I used CCS, which is based on SDK and Eclipse, for DSP.
I think the watch expression window is a very useful tool, but it is very frustrating and disappointing that this tool is not available here.
 Please give us some solution
